Reply
Nighthawk X6 R8000 Slow 5G Wifi
NettA1
Follower
Current router firwmare version: V1.0.4.62_10.1.74
I'm getting slow wireless over LAN. All tests were done at close proximity to the Nighthawk X6 R8000 router (about 6 feet away). All iperf3 averages are over 3 separate tests with a duration of 10 and an interval of 1.
Test 1: Windows 10 PC Wired -> Google Pixel 4A (5G)
Iperf3 tests average 312 Mbps
Test 2: Google Pixel 4A (5G) -> WIndows 10 PC Wired
iperf3 tests average 207 Mbps
Test 3: Google Pixel 4A (5G) -> Huawie MediaPad M5 Tablet (5G)
 iperf tests average 183 Mbps
Test 4: Huawei MediaPad M6 Tablet (5G) -> Windows 10 PC Wired
iperf tests average 283 Mbps
I understand that "up to 1300 Mbps" is a pretty loose term, but getting 20% of that at best seems silly to me.. I looked through some reviews of the Nighthawk X6 AC3200 wifi and found users typically getting 600 - 800 Mbps. I'm wondering if anyone else is seeing slow wifi speeds like this?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Guru
Re: Nighthawk X6 R8000 Slow 5G Wifi
I'm not sure where you were seeing people getting 600-800mbps but I'm betting it wasn't over wireless.
Take a look at an actual review/testing site.
https://www.smallnetbuilder.com/wireless/wireless-reviews/32489-netgear-r8000-nighthawk-x6-review-pa...
the standard 5ghz speed under OPTIMAL conditions is around the 240-270mbps. the triband routers aren't as fast in single device testing but allowed concurrent (more than 1 device) to perform at those speeds because each could be on a seperate 5ghz band.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
As @plemans suggests, beware ad speak.
As well as that link, here's another good one.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 346 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
