Reply
Nighthawk X6 R8000 Wifi Schedule
kwlave21
Follower
I have been trying to set up a daily wifi schedule so that the wifi turns on at 12pm and turns off at 8pm daily.  I have gone to the advanced settings, set a schedule, hit apply and thought I had implemented a schedule.  However, the next day the wifi turns on and eventhough the wifi settings indicates the schedule is active, it is not.  I am not very tech savvy.   Kindly can someone please provide some guidance as to how I set the schedule so that I can set a schedule.  I have enabled all three bands and checked the box for setting the wifi by schedule.
The router is using V1.0.4.28_10.1.54 firmware.
thank you
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk X6 R8000 Wifi Schedule
You may want to take a look at this KB to make sure you didn't miss anything.
https://kb.netgear.com/24102/How-do-I-set-up-the-wireless-schedule-on-my-Nighthawk-router
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 427 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
