Reply
Nighthawk X6 R8000 slow download speed only WIFI and VPN (AP MODE)
ZsoltiD
Hi all,
I have a Nighthawk X6 R8000.
Firmware version: V1.0.4.68_10.1.75
I'm working from home and I found that when I connected my laptop (and Cisco VPN connection was enabled on the laptop) to the Netgear via WIFI, then the download speed was very low. The upload speed was normal.
If I connected my laptop ( and VPN connection was disabled on the laptop) to the Netgear via WIFI, then the download and upload speed were normal.
If I connected the laptop via Ethernet port, both of them were normal when the VPN was enabled or disabled.
So the problem occured only in case of WIFI and VPN ON. (I tried 2.4 and 5GHz WIFI and WMM is switched OFF under QOS settings.)
My router is in AP mode (a lot of functions are not available under the menus). Unfortunatelly, the result was the same after factory reset too. Smiley Sad
Do you have any idea? What can be the problem?
Br,
ZsoltiD
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 9
Guru
Re: Nighthawk X6 R8000 slow download speed only WIFI and VPN (AP MODE)
When you're using your vpn, all the data on that device has to go through the vpn. so if it (the vpn) doesn't have the speed/capability then the vpn will be the bottleneck.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 9
ZsoltiD
But I tried to connect it to my mobile hotspot (WIFI) as well and the result is that the download and upload speed are very well when the VPN is enabled. Not to mention that over Ethernet, the VPN works perfectly on the same router
Message 3 of 9
Guru
have you checked with your vpn provider to see if there's any certain settings needed?
Message 4 of 9
ZsoltiD
Not yet, but most of my colleagues (about 20-25 colleagues) are not competent in the settings of the routers, and they don't have this problem with the VPN which is the same as mine. They didn't set anything at home, and it is working perfectly there ...
I didn't set anything on the wifi hotspot either, and yet it works, so I don't think it's a VPN problem, more likely a router or its setup issue.
Message 5 of 9
Guru
Or its an issue with the ISP.
modem+router works fine
modem+router+vpn=not working.
If it happened without the vpn, maybe I could see the router
Message 6 of 9
ZsoltiD
I set up an older router (RT-N18U) on the same network. The result is the same as under Netgear router... Smiley Frustrated
I wonder that what is the difference between connection ethernet and WIFI from VPN or from the ISP point of view.
How can it work well over ethernet while not good on WIFI? The local network is the same in each case.
Message 7 of 9
Guru
so if 2 routers are having the same issue then the only variables that are the same are your ISP and the VPN.
Message 8 of 9
RobGar
The reporter is saying that speed while on VPN is fine while cabled to the router as well as wirelessly on a hotsopt.  Why are you saying it's the VPN or the ISP when only slow on Wifi with the two routers the person used?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 388 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
