Reply
Nighthawk X6 Reset
TonyT75
Follower
Nighthawk X6 Reset
I am unable to reset this router. I’ve tried holding the reset button for 15 seconds, and I’ve also tried doing the 30-30-30 method. Nothing makes it so the original SSID shows up. It’s instead another that seems stuck assigned to the router. I can’t login to the web UI either, unable to find the server or something along those lines. I really don’t want to trash this since it was a $300 router. Please help.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Re: Nighthawk X6 Reset
How are you trying?
A wired connection to the LAN port is the best option.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 197 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
