Reply
Eric2001
Follower
Nighthawk X65 R7900P drop out every few days until I reset the router
I purchased Nighthawk X65 R7900P model from Costco ~3 weeks ago. It seemed to work ok for the first week, then started to drop out every 2-3 days until I manually restarted the router.  Is there any latest firmware update from Netgear to fix the issue? or shall I just return this device?
Any help will be apprecaited.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 4
KingKnucklehead
Re: Nighthawk X65 R7900P drop out every few days until I reset the router
I bought my Nighthawk around the same time and purchased it from Costco, I am having the same exact issue that I can’t figure out and it’s getting pretty frustrating
Message 2 of 4
mtgn
just bought nighthawk X6 AC3000 from costco.  Goes offline every 2 or 3 days and must be reset.  Very inconvenient!  Is there a fix for this???
Message 3 of 4
adamshaban1
I am having same issue with the router I purchased from Costco. Updated to the latest firware as well and works fine for a few days but then requires a restart to regain internet access. Im using FIOS internet modem
Newest firmware is suppose to address internet disconnect issues but doesnt. If this isnt fixed soon mine is going back to Costco unfortunately!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 579 views
  • 0 kudos
  • 4 in conversation
Announcements
