Reply
Nighthawk X6S AC3000 Unable to connect to an outdoor device
GMORE
Follower
I am unable to connect to a 2.4 GHz devise-outdoor Recteq grill.  I am using their app for wifi connection and instructions.   The indoor router is aprox 40ft max from the grill and the signal must travel thru two interior and one exterior walls. Instructions have been followed and the grill light blinks, but the grill and iphone will not connect.  Please advise, I need help. Thx
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 2
Guru
Re: Nighthawk X6S AC3000 Unable to connect to an outdoor device
What modem/gateway do you have the router connected to?
What are the exterior walls of your home made of? Things like metal (steel siding), brick,adobe, etc are all great at blocking wifi.
when you're setting it up, do you have your iphone on the 2.4ghz signal? That's another key.
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 120 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
