Reply
Nighthawk X6S hooked up to the Uplink port on my switch
1956msg
Follower
Hi to all,
I'm trying to hookup my Nighthawk X6S to the uplink port(not Std port) on a BV Tech 18 port switch(unmanged). The lights on the Nighthawk show it links up and all go white but when I hook to the Wifi with my phone it shows connected but no internet.  I don't klnow if the uplink port on this switch is Auto mdi-mdi-x  so is it possible I need a crossover cable? the cable is running from the uplink port on switch to the Internet port on the Nighthawk. The red light switches to white showing the completed link but get no actual internet even thou it shows connected?
Thanks
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 2
antinode
Guru
Re: Nighthawk X6S hooked up to the Uplink port on my switch
> on a BV Tech 18 port switch(unmanged). [...]
   Why?  What is the actual problem which you are trying to solve?
> [...] The lights on the Nighthawk [...]
   _Which_ "The lights on the Nighthawk" do what, exactly?
> [...] show it links up and all go white but when I hook to the Wifi
   Where/what is the Internet connection in this arrangement?
> [...] I don't klnow if the uplink port on this switch is Auto
> mdi-mdi-x so is it possible I need a crossover cable? [...]
   Anyone who can see an actual model number for your (unspecified) "a
BV Tech 18 port switch(unmanged)" might be able to find some
documentation for it, which might reveal that.  Which leaves me out.
How about you?  But didn't you say that some LEDs or other "show it
links up" properly?  I'd expect the Ethernet ports on a R7900P to
accommodate almost anything, but the documentation on that device should
say.
> [...] the cable is running from the uplink port on switch to the
> Internet port on the Nighthawk. [...]
   Ok.  But where/what is the Internet connection in this arrangement?
Is there some kind of modem involved?  (How, exactly?)
> [...] The red light switches to white [...]
   _Which_ "The red light" (on which device)?
> [...] showing the completed link but get no actual internet even thou
> it shows connected?
   "it shows connected"?  What, exactly, does it show is connected to
what, exactly?  Where/what is the Internet connection in this
arrangement?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 246 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
