- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X6S stopped working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Nighthawk X6S stopped working
I had mine do something similiar after a quick power outage. Most likely it lost its settings or got stuck in a loop during an update or the power just caused a glitch.
Do a hard factory reset on the back.. you may have to do twice....then go back and do a setup all over again. That should get it back up and running...especially if you can get the green light back on in the back, instead of red.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not sure, but could be a hardware failure...maybe someone with more experience with the extender issues could chime in.
Mine had all flashing lights and a red flashing in the back..and the hard reset fixed that....yours sounds like a bit different issue though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not sure..but try using an app that scans for devices..your extender might have reset to a new IP and is not showing up on the network because of it.. if you can find the IP..then you should be able to log in and get everything reset...
You could also try to use the WPS button on the extender and router to see if you can force it to find it and re-connect as well.
Good luck.
