Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk XR1000 no internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-06-30
11:49 AM
2022-06-30
11:49 AM
I have an Arris TM1602 modem that shows that it is connected to the internet. Although, my Nighthawk XR1000 shows that both wifi bands are able to be connected to, they don’t have access to internet. They are only “connected locally” as it says. I am not sure what steps I should take to get the router fully connected to the internet.
Solved! Go to Solution.
Message 1 of 10
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-01
09:20 AM
2022-07-01
09:20 AM
You can either hold the reset button in the back of the router with a pin or something similar for 30 seconds, wait 2 minutes then access the interface and go through the wizard or
instead of the physical button, if you have access you can go to Settings > Administration > Backup Settings and click erase
Message 8 of 10
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-06-30
03:21 PM
2022-06-30
03:21 PM
Re: Nighthawk XR1000 no internet
Using WPA2 and AES only for security?
Have you tried a factory reset and setup from scratch using a wired PC?
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-06-30
04:01 PM
2022-06-30
04:01 PM
Do you get internet through ethernet on the XR? Are you able to access the interface at all? If this is your first time with the router have you accessed and completed the setup wizard as you will need to do that to get internet.
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-06-30
07:03 PM
2022-06-30
07:03 PM
The firmware is up to date. WPA2 password for security. I have tried factory resetting from my phone but I don’t have a pc with an Ethernet port - all fairly new laptops.
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-06-30
07:06 PM
2022-06-30
07:06 PM
No, this isn’t the first time using the router. I had just gotten a new modem from my ISP due to transferring service from my sister and into my name. (Therefore new account warrants new equipment.) and it was working just fine with the old router. Not sure why this new one won’t pick up signal.
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-01
02:29 AM
2022-07-01
02:29 AM
If you connect directly to the new modem, do you have internet access?
From a device connected to the XR1000 via Wi-Fi, are you able to get to the XR1000 interface by going to 192.168.1.1 in the web browser?
Since factory resetting the XR, you'll need to run through the setup wizard again to get a connection.
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-01
09:07 AM
2022-07-01
09:07 AM
Perhaps I’m not doing the factory reset properly. Could you run me through the steps of doing a factory reset? Maybe I’m missing something…
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-01
09:20 AM
2022-07-01
09:20 AM
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-01
04:18 PM
2022-07-01
04:18 PM
Turns out my ISP sent me the wrong modem. 🙄 I then followed your factory reset tips and got er working. Thanks a ton!
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-02
04:03 AM
2022-07-02
04:03 AM
Great to hear that, thanks for the update!
Message 10 of 10
Announcements
