- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk ac1750 won’t connect to internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk ac1750 won’t connect to internet
You're using the T25 as the modem?
And you have the C6300 for a router?
Or what actual router do you have?
(hint, ac1750 is a speed)
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Just installed arris T25 [...]
Ok. That's a cable-TV modem. "installed" _how_, exactly?
> [...] netgear will not connect to the internet when plug the same
> cable that was connected to my computer, [...]
Huh? What, exactly, are you connecting to what, exactly? (Hint: If
a device has different types of Ethernet ports, then "connected to
device" is not enough detail.)
> [...] tired of unplugging the modem [...]
Which one? From what?
What, exactly, are you trying to do with these devices?
> Model: C6300|AC1750 Cable Modem Router Docsis 3.0
That's a cable-TV modem+router. It can't be used as a router with
some external modem (because it lacks a WAN/Internet Ethernet port to
which to connect an external modem).
