- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk cx80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk cx80
I Just Bought Nighthawk CX80, Modem Router Build In. I Realize Internet Doesn't Works On Some Device. Laptop And Tv Works, But 2 phone And Tv Box It Doesnt.Doesn't. In Tv Box It Usually Says Less Connectivity Place Your Box Close To Router. Can Anybody Help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk cx80
The more appropriate community section would be Cable Modems & Routers - I'll request a moderator moving your thread
Hard to guess, lack of details.
All wireless or some wired Ethernet/LAN connections?
What make, model, and OS version of the phones?
PS. Curious where you have typed your message - probably a mobile browser? Wondering because I have seen this forced upper-casing under some conditions, too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk cx80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk cx80
are you using wpa3?
I've seen a few devices struggle with wpa3.
You can try using wpa2.
like @schumaku says, what devices are having the issues?
Wired/wireless?
Are you using smart connect?
Try disabling it and then seeing if it matters if those devices are connecting to 2.4ghz or 5ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk cx80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk cx80
@plemans wrote:
are you using wpa3?
Yeah, however according to the UM thee is no WPA3 option. A difference to older Netgear routers is that it defaults to WPA2-PSK (AES), the mixed mode WPA2-PSK (AES) + WPA-PSK (TKIP) is disabled by default [what makes sense to avoid people reporting their Apple devices are reporting poor config].
