Reply
Nighthawk drop internet
lon000007
The Nighthawk wifi router keeps dropping internet connect, then restart, connected and drop. I try to reset the router it doesn't work, update the new firmware it doesn't work, I really need some help.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
antinode
Guru
Re: Nighthawk drop internet
> [...] I try to reset the router it doesn't work, update the new
> firmware it doesn't work, [...]
   "try to reset"?  "try"?  What, exactly, did you do?  What, exactly,
happened when you did it?
   _What_, exactly, "doesn't work"?  Does the settings reset operation
not reset the settings, or does a settings reset not solve the problem,
or what?
   What is this "the new firmware"?  What was the old firmware?  Does
the firmware load operation fail, or does the (unspecified) "the new
firmware" not solve the problem, or what?
   Is that accurate?  Many reports here suggest that version V1.0.9.42
causes fewer problems than later versions.
Message 2 of 4
lon000007
reset, press the reset button at the back of the router, unit reboot and setting reset, still have the issue
firmware, i have no clue which firmware, it was the nighthawk app insist to install the later version, before i can log in the app either the old or the later firmware it does not solve the problem
should i buy a new one?
Message 3 of 4
antinode
Guru
> [...] the nighthawk app insist to install the later version, [...]
   Use a web browser instead of some Netgear app?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.
> [...] should i buy a new one?
   If you can't solve the problem, ...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 725 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
