Reply
Nighthawk failed installation
NC54
Follower
Warning: See model number below (which was not a drop down box option)
After installation the Nighthawk app failed to operate correctly on my phone. It opened to a black and totally unresponsive screen. I needed to reboot my phone to get out of it. Reinstallation did not fix the problem.
My phone: Xaomi Redmi Note 4, Android version 6.0.1
Router: AX1800 WiFi 6 Router (RAX20)
How do I get Nighthawk to work on my phone?
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Guru
Re: Nighthawk failed installation
You might have better luck posting in the actual app forum.
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
If it was me, I wouldn't use the app at all. I prefer the browser
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 120 views
  • 0 kudos
  • 2 in conversation
Announcements
