Reply
Nighthawk is intalled BUT is not connected to int-net
bobog
Follower
Have an ASUS router currently.   It is working fine.  Finds Internet, etc.
Trying to "install" the Nighthawk router as per instructions, but each time, I get  "Connected but No Internet".   What should I do?
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 3
Guru
Re: Nighthawk is intalled BUT is not connected to int-net
Are you going this route:
modem (which is?)--------->Asus router (? model)------->R7900P?
If so, unless you placed the netgear in AP mode, you're in a double nat and can easily get that notice.
https://kb.netgear.com/30186/What-is-Double-NAT
If you plan on keeping that setup, place the R7900P in AP (access point) mode or you have 2 routers both trying to manage your routing setup.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
.... and remember to reboot the network in the right order.
  • Turn off and unplug modem.
  • Turn off router and computers.
  • Plug in and turn on modem. Wait 2 minutes for it to connect.
  • Turn on the router and wait 2 minutes for it connect.
  • Turn on computers and rest of network.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 210 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
