- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk mesh mr60 dead
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
With contacting support, you can still start the rma process through the support site. If they contact you, they might try to charge you but if its a hardware warranty issue and not just fixing a setting, it doesn't cost. I usually make them admit it up front just in case.
https://kb.netgear.com/1162/How-can-I-get-a-Return-Material-Authorization
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk mesh mr60 dead
Is the power light on?
did you try swapping the power supply on the satellite with the router?
You should still be able to start the warranty process through support if its dead.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
