Reply
Nighthawk not connecting to internet during setup
jasonpele
Follower
I recently purchased a brand new ac1900 smart wifi router. During the initial setup of the router, everything works without issue until it attempts to connect to the internet. It has been unable to connect (blinking orange light for internet connection, picture attached), I have followed the reset procedures for the modem and router twice (unplugging both, waiting, replugging in modem, letting modem fully reboot, plugging in router).
I live in Japan and have au/KDDI as an internet provider. There is no issue with the modem itself. I apologize if I am leaving out any pertinent pieces of information. Thank you for the help
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Re: Nighthawk not connecting to internet during setup
What is the modem?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Greetings,
@jasonpele , answering the following questions might help.
AU/KDDI Internet..  What kind of service is it?  Fiber, Cable, DSL, etc?
Is a username and password required?
What's in front of the Nightwawk as @michaelkenward asked?
Modem only? Modem / Router combo?  If the device is a modem / router combo, you may need to put it in pass-through or bridge mode.
Does is have more than one LAN port?  Can multiple devices be connected to it?
"Its been unable to connect", LED stays orange.  OK...  connect a PC to the Nighhawk via ethernet.  Open a browser and enter 192.168.1.1 or routerlogin.net
Default Username: admin
Default password: password
Advanced tab > Set Up Wizard (nav pane).
Radio button > Yes (Smart Wizard automatically detect my connection) type
Press Next....
What happens?  Error messages, etc?
We will wait for your reply.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 939 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
