Orbi WiFi 7 RBE973
Reply
Nighthawk r6700 speeds worse after updates
Synvious
I've had this issue for along time, seemingly when my router gets a new firmware update it slows the download and upload speeds significatly, currently I have been using V1.0.3.66_10.0.50 as this update seems to be the the most recent update that gives me ok speeds. I have tested my speeds with the gateway provided from my isp and the speeds are as they should be, both wifi and Ethernet are affected.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
Guru
Re: Nighthawk r6700 speeds worse after updates
After the update, did you try a factory reset?
Sometimes that can help after a firmware change.
Message 2 of 3
Synvious
I Just tried this and it did significantly help upload speed it tanks my download, when from about 300+ download to 70
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 467 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
