- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk r7000 and app
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having issues with Ubisoft. Long story short they want me to port forward. I had to hard reset the router some time ago. Now, I use the app and I cannot connect to the network of the router. I am connected to the correct wifi connection and the app sees it but says I am disconnected. I am not sure how to solve this.
Every time I go to routerlogin.net I am redirected to the Netgear website and it cycles around.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000 and app
1. what firmware is on the router?
2. what gateway/modem is the router connected to?
3. does the IP address of the router work?
4. why does ubisoft think you need to port forward?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2. How do I find it out?
3. Is it 192.168.1.1? If so, then no. It times out.
4. Because I can't access AC Valhalla add-ons on my PS5 despite no other problems with anything at all
- Mark as New
- Bookmark
- Subscribe
- Permalink
@afcbmike wrote:
1. I don't know as I can't access the router---
2. How do I find it out?----follow the little wire thats plugged into the wan port of the router. That'll lead back to something with a model number on it.
3. Is it 192.168.1.1? If so, then no. It times out.---it might have changed if your gateway is a combo device.
Your router might have used a different ip address if it detected a double nat (cascading routers) issue. its why we ask.
Try disconnecting the router from the modem, reboot the router, connect a pc/laptop to the router. then pull up a command prompt and type "ipconfig" the default gateway is the routers ip address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:
2. How do I find it out?----follow the little wire thats plugged into the wan port of the router. That'll lead back to something with a model number on it. The model numebr of my Nighthawk router isR700 although you asked for a gateway?
4. Because I can't access AC Valhalla add-ons on my PS5 despite no other problems with anything at allYour router might have used a different ip address if it detected a double nat (cascading routers) issue. its why we ask.
So I purchased this Netgear Nighthawk R7000 so I could applu ExpressVPN on to it. All good until Ubisoft. I was advised to hard reset the router. Now I cannot access it on the app. It looks for the WiFi connection of the same name, which I am connected to, but the device is not recognised.
I just followed your steps of accessing the router after disconnecting it from the modem. The default gateway address just takes me to ExpressVPN router dashboard. Not the actual router settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I purchased this Netgear Nighthawk R7000 so I could applu
> ExpressVPN on to it. [...]
Ok. Now you have an ExpressVPN router, not a Netgear router.
> [...] the device is not recognised.
Because, with ExpressVPN firmware, it no longer acts as a Netgear
R7000.
> [...] The default gateway address just takes me to ExpressVPN router
> dashboard. [...]
That's what your router does when you load ExpressVPN firmware on it.
> [...] Not the actual router settings.
Those _are_ "the actual router settings", now.
If you want to use a Netgear app to control your router, then load
some Netgear firmware onto it. If you want the ExpressVPN firmware on
it, then you need to deal with the ExpressVPN firmware.
Did you read about the ExpressVPN firmware before loading it onto
your router?
