Reply
Nighthawk r7000 losing external harddrive connection randomly
shayaant
Hello,
I have netgear nighthawk R7000 (See firmware version below). I have a WD easystore 8tb drive connected to the usb 3.0 port and for some reason I randomly lose connection to it. You can see below it loses connection for about 7 seconds and then is attached back. This never happened before with my other drive connected to usb 2.0, but now since I started using the WD easystore as well, both drives seem to lose connection but it only logs one of them.
Any ideas?
[Admin login] from source 192.168.1.3, Monday, Mar 05,2018 05:27:56
[USB device attached] The USB storage device WD easystore 25FB (easystore) is attached to the route Monday, Mar 05,2018 05:27:31
[USB device detached] The USB storage device WD easystore 25FB (easystore) is removed from the rout Monday, Mar 05,2018 05:27:24
Firmware Version
V1.0.5.64_1.1.88
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Re: Nighthawk r7000 losing external harddrive connection randomly
@shayaant wrote:
Firmware Version
V1.0.5.64_1.1.88
That is seriously old firmware. November 2016. There have been near on a dozen newer versions since then.
An update is no guarantee that it will work – you have done well to get a drive that large to work – but it might be worth trying.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 5
shayaant
upgraded to V1.0.9.26_10.2.31
still occurring
[Admin login] from source 192.168.1.3, Saturday, Mar 17,2018 06:16:53
[DHCP IP: (192.168.1.7)] to MAC address 08:00:27:0B:BC:9D, Saturday, Mar 17,2018 06:16:48
[USB device attached] The USB storage device WD easystore 25FB (easystore) is attached to the rou Saturday, Mar 17,2018 06:16:15
[USB device detached] The USB storage device WD easystore 25FB (easystore) is removed from the ro Saturday, Mar 17,2018 06:16:04
any other possible solutions? Maybe the usb 3.0 or its maybe the drive? whats weird it only logs one drive is attached reattached, but both of them get into this state
Message 3 of 5
HiSpeed
Guide
I use an USB 3 flash drive always plugged on the USB 3 port and I get the same message sometime .
That's really not a problem even if I don't understand the reason.
Nevertheless, I suggest you to install v1.0.7.6_1.1.99 which is probably the best firmware...
Smiley Wink
● Netgear R7000 (Root Router)
● TP-Link Archer C7 v2 (WDS Bridge)
Message 4 of 5
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Not, unfortunately, up to date, which is par for the course at Netgear, but as @Case850 that's big for Readyshare, which seems to gag when going much over 4TB.
Just another user.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 938 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
