Reply
Nighthawk r7000p is not connecting
moobecker
After 2 years of no problems, my internet stopped connecting.  I called the internet company and they showed me that my internet was fine (plug ethernet cord into computer).  The tech said it was a problem with the router.  Where do I start to look for the problem?  Thank you
Message 1 of 4
Accepted Solutions
Guru
Re: Nighthawk r7000p is not connecting
@moobecker wrote:
Thanks for the questions.  I'm not sure I have good answers...
What firmware is on the router?  - not sure?  Nothing has changed.----Might be if auto-updates is on.
What modem/gateway is it connected to?  Comtrend NexusLink (I know this is working fine)----and it could be working perfect. But we'd like the model because sometimes a double nat can cause this issue.
What are the led's on the router doing?  The Two left (most) lights are white----None of the rest are on? Do you have anything connected to the router via ethernet? Those 2 icons are power and internet. White on internet tends to indicate its connected. But your 2.4ghz/5ghz leds are off. And if you have nothing hardwired into it, maybe the wifi on/off button got hit and shut off the wifi. Push and hold it for 2 seconds. (2nd from the right led/button)
Are you able to access the router's gui? Not sure what gui is?---thats access the router through the browser and not using the app.
Are any of my responses helpful?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 4 of 4
All Replies
Guru
Message 2 of 4
moobecker
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 441 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
