Reply
Nighthawk r7800 wont connect to new netgear cm700.
Th3-0n3
Tutor
Can any body help I bought a new modem the netgear cm700. It wont connect to my nighthawk r7800 no matter what. I can use the internet if I connect to the modem. if i connect to router to the modem it wont get any signal even tried to factory reset the router and now I keep getting this message problem detecting the internet connection.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Re: Nighthawk r7800 wont connect to new netgear cm700.
Remember, when setting up a modem and a separate router you have to reboot the whole network in the right order.
  • Turn off and unplug the modem.
  • Turn off the modem router and computers.
  • Plug in the modem and turn it on. Wait 2 minutes.
  • Turn on the modem router and wait 2 minutes.
  • Turn on the computers.
There is support for the CM700, including a manual, at the end of this link:
>>> CM700 | Product | Support | NETGEAR<<<
The Quick Start details the sequence.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Discussion stats
  • 1 reply
  • 655 views
  • 0 kudos
  • 2 in conversation
Announcements
