Reply
Nighthawk will not update model r8500 ac5300 firmware version V1.0.2.122
rob4196
Message 1 of 5
antinode
Guru
Re: Nighthawk will not update model r8500 ac5300 firmware version V1.0.2.122
   Too terse.
   "will not" is is not a useful problem description.  It does not say
what you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Message 2 of 5
myersw
Master
With the way that the Netgear firmware has been for the last year, I would say if the router is working then do not update as you could very well introduce unwanted issues.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 5
rob4196
Ok got your message. Lets try this
Using Nighthawk App on IPhone
Open app and see "UPDATE"
Click update
Checking for update
Current 1.0.2.122
New Release Available 1.0.2.130
Press "Update"
waiting about 2 no 3 minutes with "updating Firmware " message.
message "Update Error" with skip or Try Again.
Tried several times.  no luck.
Message 4 of 5
Badock
Tutor
Try downloading the firmware file onto your computer, unzip it, and log in to the router using your browser.  Go to Advanced/Administration/Router Update.  Where it says "Locate and select the upgrade file on your hard disk." tap on Browse, navigate to where you saved the unzipped firmware and select the .chk file.  Then tap on Upload.
Less chance of a bit going wrong during transmission of the file.  Also, you've now got the new firmware saved in case you need it again later.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 400 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
