Orbi WiFi 7 RBE973
Reply
Nighthawk x10, ad7200, model,9000
john8
have have a HP laser jet printer connected to the router via an ethernet cable.  the connected port shows amber.  I have powered off the xfinity modem and the routher.  at time i can print at times the printer shows offline.  currently the printer will not print and the line light is solid amber.  HOW CAN I FIX THE PROBLEM AND PRINT.  I have a wireless printer and it prints everytime.  the laserjet is not wireless capable. suggestions.  router purcased feb 2018.  thank, john
Message 1 of 5
Accepted Solutions
john8
Re: Nighthawk x10, ad7200, model,9000
thanks, i reset the printer and it works properly but i still have the steady amber light.  is this speed related?  john8
Message 3 of 5
All Replies
microchip8
Master
Amber light means the device is communicating at 10 or 100 Mbps instead of 1 Gbps. Most if not all consumer models come with a 100 Mbps network chip as it's not only a bit cheaper but also more than enough for a printer
I suggest you unplug the printer from the router, do a complete reset of the printer and plug it back in into the router
Message 2 of 5
john8
Message 3 of 5
microchip8
Master
Yes, speed related. You printer comes with a 100 Mbps network chip. When such a device is connected to a current NETGEAR router, the router will indicate it with Amber light.
I also have a printer and a few other devices with a 100 Mbps chip and they also show amber light when connected. Nothing to worry about. It's even in the documentation of your router... google your router's model for documentation and read if you're worried
Message 4 of 5
john8
thank you very much.  excellent solution and it works.  john8
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 972 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
