Reply
Nighthawk x4 does not work together with Apple Airport Extreme Time Capsule
Priost
Hello together,
I'm using my brand new Nighthawk x4 as a router to bring DHCP, DNS and Wlan to my network at home and try to use my Apple Time Capsule as a wireless Repeater for it (I was using this constelation before I purchased the x4 with a D-Link DIR 615 already). But unlike the DIR-615, the x4 don't let the Time Capsule extend the wireless network.
If I set up the time capsule and chooste to be part of the existing network everything works quite well but I need the network extension.
Does anybody have a clou what the problem may be?
Thank you in advance and please apologise my bad english
Message 1 of 2
Fairytail
Virtuoso
Re: Nighthawk x4 does not work together with Apple Airport Extreme Time Capsule
How did you setup the time capsule to work as extender with your DLINK router? If it is using a WDS(wireless distributed system) then it will not work as the x4 does not have this functionality.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 8176 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
