Reply
Nighthawk x6 AC3200
Jj_byjork
Follower
Nighthawk x6 AC3200
Hello I am looking for any possible help before I give up and return my $300 router....
I purchased this router for a dual 5ghz broad band which works just fine and is excellent. My issue is with the 2.4ghz band.... I only have one device that connects to it (my ps4) but it drops this device frequently. I have tried resetting and manually configuring but to no avail.
This signal is within 25 ft of the router (other side of a halway and down 4 ft) and always shows full bars when it is connected working with very fast speeds.... The problem lies with the router having a spasm every 1-5mins....
Any ideas On how I could fix this? It simply keeps dropping the 2.4ghz b/g/n channel.
Message 1 of 2
Retired_Member
Not applicable
Re: Nighthawk x6 AC3200
It might be interference in the 2.4 range....use auto channel and mode up to 300 on 2.4
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2273 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
