- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk x6 r8000 second 5GHz channel isn't showing on my computer but is showing on my phone
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying out having the 5GHz-2 channel but when I try to find it on my computer it doesn't show up but it does on my iPhone 6s. I can see the 5GHz-1 fine but for some reason 5GHz-2 doesn't show up. I'm currently using the archer T6e WiFi adapter in my computer.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was a good work around for it not working on the autumn update but it didn't find the second 5GHz for some reason. I recently changed my wifi adapter and that one was able to work.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk x6 r8000 second 5GHz channel isn't showing on my computer but is showing on my phone
Do you have SMART CONNECT enabled? It is possible it is managing both 5Ghz SSID's and that is the one you can connect too?
Do the other devices see both SSID's or only one?
By the way, at least on Amazon that T6e is not listed as for W10 unless you are on a specific Insider build (17025) which means the Creator Fall version or later. Might even need a new driver for it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't have SMART CONNECT on. My brothers PC was able to see and connect to it and my phone. I heard about the problems and it happened to me about the the T6e not working on the new WIN 10 update and all I did was change the PCI-E slot and it worked for me after that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So is it solved by changing slots or still having a problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
