Reply
Nighthawk x6s AC4000 Packet Loss
Cooper90
Follower
My Nighthawk X6S AC4000 is giving me packet loss. I've test the modem connection, the cat cable going from modem to router, and have diagnosed the issue lies somewhere with the router. I've factory reset the router and that still hasn't solved the issue. Has anyone else experienced this issue and figured out how to resolve this?
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 3
Guru
Re: Nighthawk x6s AC4000 Packet Loss
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
What firmware version are you on? is the packet loss only on wireless or wired both?
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 584 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
