Reply
Nighthawk x8 r8300 USB drive doesn't recognize
LIorG
I have connected at first my USB flash drive (128 gb SanDisk 3.0) and everything worked fine.
After that i wanted to copy a movie to the usb but it was FAT32 so i had to format it to NTFS.
After that the router doesn't recognize the usb.
The usb is recognize in multiple PCs
Strange...
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 2
Guru
Re: Nighthawk x8 r8300 USB drive doesn't recognize
Please post about this for your model router in this forum:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 307 views
  • 0 kudos
  • 2 in conversation
Announcements
