Reply
Nigthawk X8 / R8000 Connected Wifi, but no internet
Airbase88
The router connects to Internet perfectly for any device using LAN cable connection but not devices use WiFi connection, it shows No internet connection in NETGear Genie software and it seems not assigning IP address to the remote WiFi devices (My iPhone 6s, My Macbook...)  The router Firmware is using v 1.0.3.32 and is almost the latest version i can downloaded...
Please helps .....
Regards
Eric
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Re: Nigthawk X8 / R8000 Connected Wifi, but no internet
Has this just started happening? Or is this the initial setup?
Are the wifi lights showing on the R8000?
Have you rebooted the R8000?
The manual for the device is here:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
There is also newer firmware there.
If you do flash the firmware, then you will probably have to reset the router to its factory settings.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 5
Airbase88
Hi Michael,
The unit is brand new and this is the initial setup.
the wifi light is on and I have reboot the unit many times.
it works on LAN
Please helps ....
Regards
Eric LEE
Message 3 of 5
Airbase88
Hi Michael,
it works on LAN
Please helps
Regards
Eric LEE
Message 4 of 5
First update the firmware.
This may fix anything that is "broken".
Your firmware is 1.0.3.32. The newest is 1.0.3.36.
The easiest way to do this is to go to the device's browser interface and follow the instructions in the manual, on page 133.
Just another user.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3281 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
