Reply
No boot CFC (bootloader) NightHawk X10 R9000
Greg777777
Hi, everyone! Nearly i bought (secondhand) wi-fi router Nighthawk X10. When i power on, it light power, WAN(without insert internet cabel), guest wi-fi, usb 3.0 (2 led), wi-fi, wps, and light 6 lan led, then light 5 lan led (light off 6 lan led).....Then all lan led light orange, after it light off in all lan led. And that is all. Not responding router. I open router case, and find uart pins. After i open console terminal Putty, and power up router. I see only "CCCCCCCCCCCCCCCC" ........... After i think may by it com speed wrong, but no. What is it? Broken bootloader? Or CPU?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 7
Greg777777
Re: No boot CFC (bootloader) NightHawk X10 R9000
No it not responding, if not working bootloader, TFTP not working!!! Where save booloader in CPU or nandflash or eprom flash? How it recover?
Message 2 of 7
Greg777777
This metod working if router have good (not corrupted) bootloader CFC!!! If in UART connection in console terminal have life, then it metod will work!!! In my case no life of console terminal only "CCCCCCCCCCCCCCCCC". I think it or corrupted CPU or bootloader. But i do not no where bootloader save in nandflash or in CPU or in eprom flash.
Message 3 of 7
antinode
Guru
> No boot CFC (bootloader) [...]
   "CFE"?
      https://en.wikipedia.org/wiki/Chlorofluorocarbon
      https://en.wikipedia.org/wiki/Common_Firmware_Environment
[...] After i open console terminal Putty, and power up router. I see
   I know nothing about the low-level soft/firmware in these devices,
but are you looking at an XMODEM/YMODEM request to send a file
(repeated)?
      http://textfiles.com/programming/ymodem.txt
      As in the case of single a file, transfer, the receiver initiates
      batch file transmission by sending a "C" character (for CRC-16).
   Even if that's true, exactly what you should sent to it is a myatery
to me.
Message 4 of 7
Greg777777
It is possible to find image of NAND FLASH?
Message 5 of 7
Greg777777
Message 6 of 7
Greg777777
I find adapter and programmer to read/write fvbga63 nand flash. Now i need original full dump of this nand flash from router R9000. May be it buy some where???
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 952 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
