Reply
No connection to the internet
Mirrie
Follower
Dear support
New Nighthawk AX6 RAX 50 installed instead of my old Nightwawk X4. The old X4 has an internet connection right away and with the AX6 I don't get an internet connection, I use the app.
When I connect the old X4, all connections work again immediately.
Other devices and internet glass connection remain the same
Thx Mirrie
Message 1 of 2
Guru
Re: No connection to the internet
What modem/gateway are you connected to?
did you reboot the gateway after disconnecting the old router?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 97 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
