Reply
Not connecting to internet AX-35
tifanirj
Follower
I'm having trouble connecting to the internet.
I've factory reseted my router and it still won't connect to the internet. I also tried unplugging my modem, then plugging the router back in, ect. Also, tried to redownload the firmware and it says the file is corrupted.
I'm not too fimiliar with routers, but any help would be appreciated.
Message 1 of 6
Guru
Re: Not connecting to internet AX-35
what modem are you using?
what firmware are you on?
when you tried to upgrade the firmware, did you extract the firmware after downloading it? many don't do this so it gives you the corruption error. you can't just click on it, you have to fully extract it from the zip file.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 6
Jeff-1966
My device, after set up, is showing no internet connection. Any device that I connect to shows connection with no Internet. My desk top which is also connected to my modem works fine. What now?
Model: XR500|Nighthawk Pro Gaming Router
Message 3 of 6
Guru
@Jeff-1966 Please start your own thread if you want help. if you're on the XR500 you put in your signature, this is the forum to post in:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-rout...
Message 4 of 6
Jeff-1966
arris SB8200
Message 5 of 6
antinode
Guru
> arris SB8200
> [...] My desk top which is also connected to my modem works fine.
   Disconnect your (unspecified) "My desk top" from the modem, and
connect only the router to the modem.
      https://www.arris.com/surfboard/products/cable-modems/sb8200/
      Two 1-Gigabit Ethernet ports capable of link aggregation
   You're not doing link aggregation, are you?  Read the manual for the
SB8200?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 710 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
