Reply
Not getting the correct speed AC1000 Model R6080
jamespatrom191
Follower
I have a 300 mbps service. I connected the wire from the box directly to the computer and the speed test says 285 mbps, but when i connect it with the wire from the router or the computer or with the wifi it only gives 35 mbps. How can i solve this issue?
Model: A6200|802.11ac Dual Band WiFi USB Adapter
Message 1 of 2
Guru
Re: Not getting the correct speed AC1000 Model R6080
a couple things wrong with this.
the R6080 isn't gigabit capable. Its rated for fast ethernet or 10/100 speeds. if you have 300mbps, you'll max out around 96mbps over a hardwired connection.
You should still get faster than the 35mbps but you'll never see the speeds you're paying for.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 391 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
