Reply
Only certain ports forward
cowduck
Luminary
I can only forward 3389 (custom), 12794 (OpenVPN default), and remote management (8443).
If I change the default OpenVPN and remote management port and test the port on a port checker I get a "success" message, and I am actually able to access the service remotely.
For example, changing the remote management port to 5900 via the "Port Number" dialog is a success.
Adding a custom port forward (other than 3389) like 5900 (vnc) does not work.
Why is this happening?
Message 1 of 5
Re: Only certain ports forward
Greetings,
You may have got yourself I some sort of error condition. I have several port forwarding rules in place, all of which are working. If your configuration doesn't appear to be working as expected, start over (clean slate). A hard reset often resolves these unexplainable issues.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 5
cowduck
Luminary
Hard reset meaning a 30/30/30? Or just pressing the reset button? Thank you
Message 3 of 5
jmizoguchi
Virtuoso
any of should work. 20/20/20 or 10sec, 60 sec.
see router reset on my sig below for your options .
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 4 of 5
cowduck
Luminary
Router was returned after multiple resets. Now everything works well. Hopefully the R8000 fixes these little issues.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1933 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
