Discussion stats
  • 5 replies
  • 2862 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Ookla different speed results
My internet was recently updated to 200 Mbps.
When I connect my laptop (wired) to the cable modem (Arris SB6183) I get speeds of around 240 Mbps at https://speedtest.net.
When I use the same speedtest on the QOS admin screen on my R8000 the highest I can get it is 199 Mbps.
Anybody having an idea why there is such a huge difference between the two Ookla speedtests?
Thank you
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 6
Highlighted
NETGEAR Employee Retired
Re: Ookla different speed results
Welcome to the community, @Urdypooh
 Do you have the latest firmware update on your router?
How many times you have tried testing the speed?
ElaineM
NETGEAR Community Team
Message 2 of 6
Highlighted
I had tried it about 5 or 6 time at different hours.
And yes. I have the latest firmware on my router.
Message 3 of 6
Highlighted
Did you try to factory reset
If you did, is this also happening on previous firmware version?
ElaineM
Message 4 of 6
Highlighted
Will a factory reset help? The problem with that solution is that I have nothing configured apart from the SSID, the access passwords and me having enabled QOS.
And no. I have not tried previous firmware because the new internet speed came with the new firmware. (With the former firmware and the speed of 150 Mbps it was shown  ok in both speedtests.)
Message 5 of 6
Highlighted
Most of the time resetting the unit helps. So, I suggest that give it a try.
ElaineM
Message 6 of 6
