snachnani's avatar
snachnani
Follower
Nov 16, 2020
Ooma Telo compatibility
I have upgraded to xfinity cable modem router Nighthawk CAX80. Currently my OOMA Telo device is not working with he current router. Is this router compatible with Ooma Telo? Also if I attach a Orbi RBK753S mesh system to the mix, is OOma Telo compatible with the Orbi Mesh System?
Any insights/advise would be appreciated.
Thx.
Sudhir
1 Reply
  • plemans's avatar
    it should.
    If you're having issues, I'd contact ooma
