Reply
Open VPN; DDNS
pupster
Follower
Open VPN; DDNS
1) Any way to set up Open VPN with my OWN certificates/config files?
2) Any way to add support for afraid.org DNS servers?
If none of the above and DDWRT isn't working on this, then this is going back to New Egg before the 60 days are up....
Message 1 of 2
jmizoguchi
Virtuoso
Re: Open VPN; DDNS
R7000/8000 bot hare using third party openvpn and not sure they regular service even support that but if does it would limitation on how netgear design to use with openvpn. Even encryption are only supported 1024
DDNS is limited to what you see in the GUI.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 7411 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
