- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OpenVPN 1.1.22 Android
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ever since The Android app of OpenVPN updated to 1.1.22 I can no longer connect to my router. It give OpenVPN server certificate verification failed : mbed TLS: SSL read error : X509 - Certificate verification failed, e.g. CRL, CA or signature check failed
How do I make this work again?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
As as update 1.1.24 of OpenVPN Connect has fixed the solution. According to the changelog though, they relaxed the certifaction validation in mbedTLS to allow certificates with broken date format to connect and re-enevabled depricated and INSECURE md5 signature algorithm. SUpport for md5 will be officially dropped on April 31, 2018.
I'm not exactly sure which of the two caused the problem, if it's the later, I hope Netgear updates the OpenVPN server software in the a firmware update before then.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OpenVPN 1.1.22
Hi.
I've just updated the openvpn android app to 1.1.22 (build 89) and I'm getting exactly the same problem.
Can anyone help?
Thanks,
Carlos
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OpenVPN 1.1.22
Beside use older APK, you can consider try this solution from my post:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OpenVPN 1.1.22
Hi @thepretender.
Thanks for the help and the link.
I believe when I say that, speaking for @Jfossy if I may, we where using the OpenVPN Connect app. Please Jfossy correct me if I'm wrong. At least I was using that app.
Using the instructions on the link you send (with OpenVPN for Android app) I was able to connect to the vpn. Thank you again for the help.
Carlos
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OpenVPN 1.1.22
I get the same error after an update of OpenVPN on Android.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OpenVPN 1.1.22
Yes I was referring to the OpenVPN Connect App. However, like you, using the other OpenVPN and the instructions, I am able to connect. I just wish Netgear / OpenVPN Connect would get on the same page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OpenVPN 1.1.22
- Mark as New
- Bookmark
- Subscribe
- Permalink
