Orbi WiFi 7 RBE973
Reply
OpenVPN Error
sosready
OpenVPN Error
We have been succesfully connecting to a Netgear R8000 (FW: V1.03.46_1.1.32) router using OpenVPN since August 2017. Recently, we could not connect and we did not make any changes to the OpenVPN software. We are not sure what version of the software we were using because we uninstalled it before looking at that or the logs ;(  So we decided to download the latest version 2.4.5 and replace our config files with fresh copy from the router. We got this error on connection attempt:
 WARNING: No server certificate verification method has been enabled.
OpenSSL: error:140AB18E:SSL routines:SSL_CTX_use_certificate:ca md too weak
OpenSSL reproted a certificate with a weak hash, please the in app FAQ about weak hashes
Cannot load inline certificate file
Exiting due to fatal error
We decided to go back a version of OpenVPN to  2.4.3 and we could connect ok.  How can we get version 2.4.5 to work-it must be more secure.
Thank you!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router,R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 4
Accepted Solutions
JamesGL
Master
Re: OpenVPN Error
Message 3 of 4
All Replies
Diggie3
Luminary
Re: OpenVPN Error
Netgear is shipping routers with certificates that use the md5 digest, and OpenVPN considers it too weak and won't connect to it.
You can find one solution here:
https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/R6250-with-OpenVPN-2-4-5/m-p/1529598#M...
Message 2 of 4
JamesGL
Master
Re: OpenVPN Error
Hi sosready,
Please try this new firmware.
https://kb.netgear.com/000058796/R8000-Firmware-Version-1-0-4-18
Message 3 of 4
JamesGL
Master
Re: OpenVPN Error
Hi sosready,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 14028 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
