Scrif2016
Sep 27, 2017Aspirant
OpenVPN, IOS 11 - how to import ovpn, certs, key files
Updated my iPhone to IOS 11 and have to re-install my ovpn, certs, and key files. Tried to do it through the new 'files' app in IOS 11 but it doesn't seem to work. Don't want to use email to do it.
Any help would be appreciated.
Got my answer from someone on Reddit. (Isn't this supposed to be a Netgear support forum?)
Anyway....FYI for anyone else:
- connect phone to pc and open iTunes
- select file sharing from left hand side
- find OpenVPN in the app list - select 'add file' at the bottom of the iTunes screen (you may have to scroll down)
- add your ovpn, certs, key files
- sync iPhone -open OpenVPN on iPhone
- you should see a new profile ready to be added
1 Reply
- Scrif2016Aspirant
