- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
OpenVPN TLS error
OpenVPN will not connect, fails at
"Wed Feb 08 11:10:47 2017 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Wed Feb 08 11:10:47 2017 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Wed Feb 08 11:11:47 2017 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Feb 08 11:11:47 2017 TLS Error: TLS handshake failed
Wed Feb 08 11:11:47 2017 TCP/UDP: Closing socket
Wed Feb 08 11:11:47 2017 SIGUSR1[soft,tls-error] received, process restarting
Wed Feb 08 11:11:47 2017 MANAGEMENT: >STATE:1486581107,RECONNECTING,tls-error,,
Wed Feb 08 11:11:47 2017 Restart pause, 2 second(s)
Wed Feb 08 11:11:49 2017 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Feb 08 11:11:49 2017 Re-using SSL/TLS context
Wed Feb 08 11:11:49 2017 LZO compression initialized
Wed Feb 08 11:11:49 2017 Control Channel MTU parms [ L:1590 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Wed Feb 08 11:11:49 2017 Socket Buffers: R=[65536->65536] S=[65536->65536]
Wed Feb 08 11:11:49 2017 MANAGEMENT: >STATE:1486581109,RESOLVE,,,
Wed Feb 08 11:11:49 2017 Data Channel MTU parms [ L:1590 D:1450 EF:58 EB:143 ET:32 EL:3 AF:3/1 ]
Wed Feb 08 11:11:49 2017 Local Options String: 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Wed Feb 08 11:11:49 2017 Expected Remote Options String: 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Wed Feb 08 11:11:49 2017 Local Options hash (VER=V4): 'b498be7c'
Wed Feb 08 11:11:49 2017 Expected Remote Options hash (VER=V4): '26e19fc0'
Wed Feb 08 11:11:49 2017 UDPv4 link local: [undef]
Wed Feb 08 11:11:49 2017 UDPv4 link remote: [AF_INET]xx.xxx.xxx.xxx:12974
Wed Feb 08 11:11:49 2017 MANAGEMENT: >STATE:1486581109,WAIT,,,
Wed Feb 08 11:11:49 2017 MANAGEMENT: >STATE:1486581109,AUTH,,,
Wed Feb 08 11:11:49 2017 TLS: Initial packet from [AF_INET]xx.xx.xxx.xxx:12974, sid=c3140251 ab94e37b
Wed Feb 08 11:11:49 2017 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Wed Feb 08 11:11:49 2017 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
removed my IP address and replaced with XXX.
Hardware Version | R8000 |
Firmware Version | V1.0.3.32_1.1.21 |
GUI Language Version | V1.0.3.32_2.1.49.1 |
VPN was working for consistently for the last couple of weeks, no changes have been made.
There is a working internet connection, since I am able to initially connect to the modem remotely, as well as use remote access tools to access my internal network remotely.
Router has been rebooted and power cycled with no change in behavior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OpenVPN TLS error
Well, it seems to be working now...is there some dependency on Netgear with OpenVPN with regards to this?
Fri Feb 10 10:36:31 2017 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
Fri Feb 10 10:36:31 2017 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
User | Count |
32 | |
15 | |
5 | |
5 | |
5 |
