Reply
OpenVPN certificate fix: Only 2 months left
chopin70
Virtuoso
@JamesGL
Following your answer here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/OpenVPN-update-breaks-R7000-and-probably-oth...
We now have only 2 months left. I cannot afford having my OpenVPN broken and waiting months for Netgear to fix it. Not updating the clients is a bad answer for security reasons obviously.
1- are there wifi routers that are confirmed as of now to support the new certificate restrictions of OpenVPN client ?
2- can Netgear communicate on devices that will get the support update before April 30 ?
At least we know if we need to change device. Two months is a short term to look and order for alternative solutions if Netgear is not going to fix it
Best regards
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Accepted Solutions
JamesGL
Master
Re: OpenVPN certificate fix: Only 2 months left
Hi chopin70,
This will be released before the April 2018 deadline.
Message 2 of 2
All Replies
JamesGL
Master
Hi chopin70,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 973 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
