Reply
Orange light after Roku Ultra installed
Thomas22
Follower
I recently added a Roku Ultra to my Nighthawk AC1900. The device seems to work fine but the Ethernet port light is orange. Is there a problem using it with a orange light?
Message 1 of 4
microchip8
Master
Re: Orange light after Roku Ultra installed
Orange indicates the device operates at 100 Mbps speed. White indicates at 1 Gbps speed. Nothing to worry. If you're sure it is 1 Gbps capable, check your cables. At least CAT5e is needed for Gbps but many recommend CAT6
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 4
antinode
Guru
> [...] my Nighthawk AC1900. [...]
   "AC1900" is a speed, not a model number.  Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier.  Look at the product label for the actual model
number.
> [...] Ethernet port light is orange. [...]
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for a
description of the LED indicators and what they indicate.  Note that
Netgear calls that color "amber".  Further reading might also be
helpful.
Message 3 of 4
schumaku
Guru
All fine - as predicted by @microchip8
https://www.roku.com/en-gb/products/roku-ultra
"Ports
Power, HDMI 2.0a, Ethernet 10/100, microSD, USB, Digital Optical Audio"
Most Netgear docs show something like this:
Ethernet ports 1-4
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
Unless the link does negotiate falsely to just 10 Mb what might be limiting the usability when it comes to video streams - everything OK.
-Kurt
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 941 views
  • 1 kudo
  • 4 in conversation
Announcements
