Reply
Orange light, another dead Netgear router
ColorofGrey
Follower
Bought this router for the range. Expensive but looks great, albeit the range was never that great.
Today no wifi. Orange power light. Looked around here, tried everything I could find without internet (obviously) looks like my newish router is a paperweight. Disappointing to read so many people here getting an orange light out of the blue like this and it just means it's broken.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 3
Re: Orange light, another dead Netgear router
The orange power LED is a sign of corrupt firmware.
Unfortunately, the R7000P has introduced the possibility of automated firmware updates. So it can try to upgrade of its own accord. I turn off that sort of thing.
You have a couple of recovery options.
First try a simple factory reset. (The pin in the back trick.)
If that fails, and the LED still looks odd, there is this:
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
You may then have to resort to this:
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.
  • Control Panel
  • Programs and Features
  • Turn Windows features on or off
  • TFTP client - enable
That's probably easier than retrieving software from a website.
Mac's also support native TFTP.
Then just follow Netgear's instructions
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
antinode
Guru
> [...] Windows has a TFTP function built in, you just have to enable
> it. [...]
   Except that after you "just have to enable it", you might need to use
it:
      https://community.netgear.com/t5/x/x/m-p/1533866#M87578
   I don't know what "native TFTP" is, but that post also shows how to
use the TFTP client program on a Mac.
   To the extent that they apply.  "Adapt", rather than "follow", I'd
say.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 29836 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
