jtkeenan1342's avatar
jtkeenan1342
Follower
May 19, 2021
Orange light on internet
Is was messing around in the router settings and I switched the router into bridge mode and I didnt know it had to reset the router and it reset and so I waited for it to reset and the internet never showed up one my computer. So I went to look at the router and the internet light was orange. And I reset it multiple times. I also factory reseted the router and the orange light is still there.
I previously had trouble with this when I was first installing the router and it eventually worked after resetting multiple times but I dont know what to do now.
1 Reply
