Orbi WiFi 7 RBE973
Reply
Overall dimensions of Nighthawk X10
Could someone please let me know the overall dimensions of the new X10 including the antenna?    The quoted numbers in the spec seem far too small from the pictures I've seen.
Thanks
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 4
Accepted Solutions
clithes
Prodigy
Re: Overall dimensions of Nighthawk X10
Yeah i'm not sure where the data sheet is getting those measurements from.
The unit measures roughly 33cm by 22cm, and is 6.5cm high.  The antennas are 18cm long, 2.5cm wide at the top and 3cm wide at the bottom.
Hope this helps
Message 2 of 4
All Replies
clithes
Prodigy
Hope this helps
Message 2 of 4
Many thanks.
Message 3 of 4
Just for the record, the overall dimesions including the antanna are:
Width:   36cm, 14.2"
Depth:  27cm, 10.6"
Height:  21cm, 8.2"
The numbers in the spec are fictional
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3894 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
