Reply
PLEX Server R9000 - Installation Not Starting
Eltron
Initiate
Hello,
I'm attempting to setup my Plex server on my brand new router, X10 R9000.  I had a PLEX server on my main system and wanted to run it off the router.  The issue I'm having right now is when I click enable plex server, nothing happens.  The box to 'open plex' stays greyed out. I have tried unchecking the boxes here, then hitting apply, rechecking, apply again, nothing.  I have tried using a 128gb disk as opposed to my standard 4tb, and nothing.
My assumption is the plex install should start after you checl download and enable PLEX server, but nothing seems to be activating.
Notes (FWIW)
I have rebooted several times.
I have an active internet connection
I have a lifetime plex pass
Running latest firmware as of today, 12-28-16. Firmware Version V1.0.1.36.
Thank you!
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
Accepted Solutions
Eltron
Initiate
Re: PLEX Server R9000 - Installation Not Starting
Just wanted to update, for some reason the plex server installed itself and am able to access and use it.  It must have been slowly in stalling the background without any notification.
Message 2 of 3
All Replies
Eltron
Initiate
Message 2 of 3
ElaineM
NETGEAR Employee Retired
@Eltron Thank you for the update! Glad to hear that it's working.
ElaineM
NETGEAR Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2814 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
