Reply
PParental controls
JAHartzell2
Follower
PParental controls
I"m not finding where I can set up controls for router shut down at certain times
can someone tell me where this might be
Thank You
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
antinode
Guru
Re: PParental controls
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "schedule"?
Message 2 of 3
Can you explain what you are trying to do?
Block all wifi access according to a schedule? Kick off some users on a schdeule? Tell the router to turn itself off?
There is support, including a manual, for the R6700 somewhere at the end of this link:
>>> R6700 | Product | Support | NETGEAR <<<
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 228 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
