stacksrp
Oct 23, 2016Aspirant
Password no longer required to Login
When using a web broswer (from a PC or smartphone connected via wired or wireless LAN) I can log into my router with out entering a password.
Is there a security setting I am missing?
I changed the password and made sure the broswer did not remember it but I can still login with out a passwrd.
Router Model R7900 firmware ver 1.0.1.4
I am concerned that my router settings could get changed by anyone connected to my LAN.
Wireless Access still requires password.
Thanks for any help on this.
After I disabled my ReadyCloud account the problem was solved.
No resetting of defaults or reloading firmware required.
- Retired_Member
reset to defaults and or try reinstalling FW
- stacksrpAspirant
Interesting. What made you try that? Inspiration or guesswork?
Well done.
I never did that mistake and I will not tolarate a dummy browsing on my gears!!
