Reply
Password no longer works after firmware upgrade on MacBook Pro
Gabby411
Seems like the whole community has bailed out. Can probably save myself a lot of frustration trying to get my password to work or reset by just buying another brand of modem/router combo. No support here to be found anywhere. Maybe I should go to the Apple community support for one last try. Out of here for good and so done with Netgear.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 3
antinode
Guru
Re: Password no longer works after firmware upgrade on MacBook Pro
> Seems like the whole community has bailed out. [...]
   Huh?
> [...] No support here to be found anywhere. [...]
   There seems to be a serious shortage of useful problem descriptions,
too.
   Not a router or a "modem/router combo".  Look for "Model" on the
product label.
   With that datum in hand, you might try this radical concept:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for the
LED descriptions and "Troubleshoot".  Further reading might not hurt,
either.
   Have you considered the advantages of accurately and precisely
describing your equipment, what you did, and what happened when you did
it?  You should.
   Here's a Web search suggestion for you (when you grow up):
      "life is like a sewer"
Message 2 of 3
Gabby411
Thanks for adding insult to injury. Wanted to get the DOIS 3.1 anyway, and I will tomorrow, this only strenthens and confirms my intention to never purchase another Netgear product of any kind. Arlo was also a defective piece of work.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 111 views
  • 0 kudos
  • 2 in conversation
Announcements
